dtarin
Sep 13, 2023Luminary
Remove readycloud users
I have a few ReadyCloud users remaining on my 516 system. The readycloud service has now shut down so how do I remove the unused users?
BMac2021
Apr 04, 2024Tutor
Is there anyway to remove cloud users now off the readyNAS?
- schumakuApr 05, 2024Guru - Experienced User
Lengthy discussion here, still open: Remove ReadyCloud Users
Challenging a moderator to merge your question there.
- StephenBApr 05, 2024Guru - Experienced User
Installing 6.10.10 might do it. Though it will also remove the ability to install apps from the web ui - if it does that, you should be able do downgrade back to 6.10.9 (which wouldn't add back any accounts).
