PeterS250's avatar
May 30, 2016
Readycloud user not connecting and non-removable
Having just updated my Readynas to the latest firmware and gone through the migration to MyNetGear, all ok for the Admin user but I have a readycloud user who having migrated to My NetGear now does not have any assigned devices? I nievely thought that I could simply remove the readycloud user and then re-invite them - In the readycloud browser app, logged in as admin, I selected the user pressed Delete button and nothing - browser indicates it is busy then nothing. The user is still present and it appears I cannot remove them from my device.
I either need to be able to re-connect them to the device or remove them completely - I don't mind which but at the moment I cannot do either - any ideas?
  • BrianL2's avatar
    BrianL2
    Jul 31, 2016
    Hi PeterS250,
    We appreciate your feedback and for letting us know how you resolve your issue. We encourage you to mark this thread closed by clicking the  "Accept as Solution" button in one of the responses that you received. We also look forward to hearing more questions, suggestions and tips from you in the future!
    Kind regards,
    BrianL
    NETGEAR Community Team
  • BrianL2's avatar
    BrianL2
    NETGEAR Employee Retired
    Hi PeterS250,
    Try to delete the said users in the local admin page under the 'Accounts' tab and select Cloud users.
    Hope this helps!
    Kind regards,
    BrianL
  • BrianL2's avatar
    BrianL2
    Hi PeterS250,
    Can you send me some screenshots?
    Kind regards,
    BrianL
    • PeterS250's avatar
      PeterS250
      Guide
      How can I send you screen shots - no ability in the forum to add in screen shots or attach files?
      I log into Readycloud go to manage select the user - on my readynas any user, and then click on delete, then get the dialogue asking for confirmation of deletion, I then click Yes and nothing happens?
      It now also appear since the upgrade that the only user who does have access is me?  All of my other users have been disconnected from the Readynas or thier accounts are simply not active anymore?
      Thanks for your help
      • BrianL2's avatar
        BrianL2
        Hi PeterS250,
        Images and screenshots can be uploaded in the community. Just ensure they are in .png format. I presume you are running Firmware 6.5.0. Were you able to merge your secondary ReadyCLOUD accounts with their respective myNETGEAR accounts (existing or new)?
        Kind regards,
        BrianL
ProSupport for Business
