gingerbenji
Dec 21, 2012Aspirant
Removed disk resync fails
Am looking for some help. Have the Duo v1. I had a 2TB WD Green disk in for several months without problem. Inserted a second a few months ago, everything sync'd properly and working well. Had someone...
Dec 21, 2012Guru - Experienced User
If you simply reinsert disk 1 into its original slot (leaving disk 2 in place) then I think it will wipe your data. Disk 1 should be treated as a new disk in that scenario.
I would check the SMART stats on drive 1, as your stalling could in principle be caused by either drive.
Maybe test both drives with WDC's Lifeguard diag?
