gingerbenji
Dec 21, 2012Aspirant
Removed disk resync fails
Am looking for some help. Have the Duo v1. I had a 2TB WD Green disk in for several months without problem. Inserted a second a few months ago, everything sync'd properly and working well. Had someone...
Dec 21, 2012Guru - Experienced User
Since this re-sync has stalled several times in a row, you should get your data off the NAS before attempting it again. So initially leave disk 2 out, and then do the backup. Then re-insert disk 2, and it should sync.
gingerbenji wrote: Hi. So is it possible that if I turn off, plug in disk 1 in bay one, disk two will then sync to this?
At the moment, disk 1 retains all your original data and your config. So with disk 1 installed by itself, you can save the configuration to your PC, and back up the data.
gingerbenji wrote: I'm sorry, I didn't understand your last sentence about configs? I think I lost this when I did a factory reset?
