altern8st8
May 02, 2013Aspirant
Removing ghost USB share
I have a new ReadyNAS 314 and am trying to sort out my backups. I connected an external USB drive for the backups to run to and at some point changed it's name from the default. Subsequently the sha...
altern8st8
May 16, 2013Aspirant
Sorted by Level3 support. Latest firmware version prohibits changing the USB's allocated name, so I guess it is a bit of a problem if you do. Took a while for them to clear out all the old references, but it's gone now.
Thank you Netgear!
Just have to get my backups working properly now...
Thank you Netgear!
