chimera388
Jul 30, 2016Aspirant
Removing invited cloud users
Good afternoon I can no longer access my NAS using the ReadyNAS Remote app, and it may be because I am getting the credentials wrong but I can't be sure. Either way, I'd like to remove my account...
- Jul 31, 2016
Hi chimera388,
Welcome to the community!
Can you confirm if both Internet & Services are marked online under the Cloud tab on the admin page? Also, tell us if you have 8.8.8.8 as DNS on the active NIC (network card) of your ReadyNAS system.
Kind regards,
BrianL
NETGEAR Community Team
chimera388
Jul 31, 2016Aspirant
Okay, that works for me but how do I add the NAS to that app? I click "devices" and it just has my Nighthawk.
chimera388
Update: I installed the ReadyNAS Remote software to my PC, but I basically have run into the same problem with not being able to log in. It won't let me get a new account because my username is taken, but it won't let me reset my password because it doesn't recognize my username/e-mail address. They can't have it both ways lol. It either exists (which it does), or it doesn't.
- chimera388Jul 31, 2016Aspirant
Update 2: Got around the login issue. ReadyCLOUD installed and configured on the NAS. App installed on phone and PC. NAS does not appear in device list on CLOUD. Have "discovered" it half a dozen times. Discovery is not persistant, and device never appears as accessible via the app.
- BrianL2Jul 31, 2016NETGEAR Employee Retired
Hi chimera388,
Kind regards,
BrianL
NETGEAR Community Team- chimera388Jul 31, 2016Aspirant
Ha! Changing the DNS did the trick. Thanks!
