Jake2
Oct 30, 2018Aspirant
Removing invited cloud users
Hello,
I would like to remove a cloud user account from Netgear ReadyNAS 31400, who are not longer working at our organisation. However, I receive the message saying I need to sign into the ReadyCloud to remove the user. After signing into the ReadyCloud, I still cannot remove the account.
The account was initially set up by someone the person has left the organisation and did not set up completely. Please could you advise? Thank you.
- Marc_VNETGEAR Employee Retired
Hi Jake2
Have you logged in the admin or main account? Please see Removing ReadyCloud users. Or possible the account you are trying to remove is where the NAS is joined to.
You may want to try deactivating ReadyCloud on the RN314. then Re-enable it. If you are not updated to 6.9.4 you may also want to do that first.
Hope this helps!
Regards
- Jake2Aspirant
Hello,
I have signed into the local admin account and tried to remove the Cloud user account. I've been pointed to remove ReadyCloud to remove the cloud user. I do not have the cloud admin account in ReadyCloud, but I have accessed to the user account in ReadyCloud and tried to remove the account without my luck.
You may want to try deactivating ReadyCloud on the RN314. then Re-enable it. If you are not updated to 6.9.4 you may also want to do that first. > No, I have not upgraded to 6.9.4.
Hope this helps!
