TheDmac
Aug 30, 2016Aspirant
Renaming a HDD
Hey guys, I know you cannot rename a HDD from within the ReadyNAS administration panel itself but I was wondering if it is possible (without causing complications) to eject the drive, insert it i...
mdgm-ntgr
Aug 30, 2016NETGEAR Employee Retired
No.
The ReadyNAS uses Linux software RAID and the BTRFS filesystem.
Renaming a volume would require using SSH (at your own risk) and would require a huge number of config changes and you could easily miss at least one. This is not something we would provide support for. Don't try this.
If you want a different volume name, backup your data, destroy the volume, create a new volume and the shares that were on it and restore your data from backup.
