adamwilde
Jul 23, 2013Aspirant
Replace original removed HD after failed disk upgrade?
Hi, We have a ReadyNAS Duo which had 2 x Seagate 500GB HDs set up as a redundant RAID disk with 500GB available storage. It was becoming full, so I checked the hard disk compatibility list and orde...
adamwilde
Many thanks, Stephen. Wise advice re the backup! I'd started a backup across the network earlier this morning to a shared USB drive as a precaution. Looks like I have about 24 hours to consider my next move while the data copies across…
It was disk1 that I removed. If I follow the procedure you outlined in your second paragraph ("If you removed disk1, etc…") would the resulting volume (once resynced) match the old state of disk1 (i.e. as it was when it was removed) or the newer state of disk2?
