adamwilde
Jul 23, 2013Aspirant
Replace original removed HD after failed disk upgrade?
Hi, We have a ReadyNAS Duo which had 2 x Seagate 500GB HDs set up as a redundant RAID disk with 500GB available storage. It was becoming full, so I checked the hard disk compatibility list and orde...
Jul 26, 2013Guru - Experienced User
That sounds slow (~2 MB/s).
Did you enable "Enable fast USB disk writes"? Also, are you able to see how far the backup has gotten?
