adamwilde
Jul 23, 2013Aspirant
Replace original removed HD after failed disk upgrade?
Hi, We have a ReadyNAS Duo which had 2 x Seagate 500GB HDs set up as a redundant RAID disk with 500GB available storage. It was becoming full, so I checked the hard disk compatibility list and orde...
Jul 26, 2013Guru - Experienced User
If you do enable it, be very careful to unmount the USB drive before you remove it. If the backup is scheduled, it is good to protect both the drive and the NAS with a UPS.
