adamwilde
Jul 23, 2013Aspirant
Replace original removed HD after failed disk upgrade?
Hi, We have a ReadyNAS Duo which had 2 x Seagate 500GB HDs set up as a redundant RAID disk with 500GB available storage. It was becoming full, so I checked the hard disk compatibility list and orde...
mdgm-ntgr
Aug 02, 2013NETGEAR Employee Retired
The dead/removed disk should be shown but with a yellow LED till it is replaced with a working disk of at least the same capacity (in the case of the Duo v1 you can't install a larger drive as 2TB is the max supported).
