adamwilde
Jul 23, 2013Aspirant
Replace original removed HD after failed disk upgrade?
Hi, We have a ReadyNAS Duo which had 2 x Seagate 500GB HDs set up as a redundant RAID disk with 500GB available storage. It was becoming full, so I checked the hard disk compatibility list and orde...
Aug 02, 2013Guru - Experienced User
I want to add that replacing a 2 TB drive with a 500 GB drive is not supported with XRAID - so you went astray when you did that.
