adamwilde
Jul 23, 2013Aspirant
Replace original removed HD after failed disk upgrade?
Hi, We have a ReadyNAS Duo which had 2 x Seagate 500GB HDs set up as a redundant RAID disk with 500GB available storage. It was becoming full, so I checked the hard disk compatibility list and orde...
adamwilde
Aug 02, 2013Aspirant
Apologies: I'd realised that I'd got volume/share muddled before you replied. We only have one share on the volume, which had caused my momentary confusion.
The reason I hadn't followed your advice to reinstall the original disc 1 when powered down without the original disk 2 was that by that point the data on disk 2 was newer than the data on disk 1 (which had been out of the Duo for a couple of days).
I guess I'll keep my fingers crossed that the WD Reds resolve everything next week. *crosses fingers*
