Raaahbin
Sep 15, 2015Aspirant
Replaced failing disk in NV+ v2 - both volume expansion and volume scan fail
Hi folks, I'm getting some slightly peculiar behaviour from my NV+ v2, and would really appreciate some help in troubleshooting. A week or so ago, I started getting errors on disk 1 of my NAS...
Sep 15, 2015Guru - Experienced User
Expansion is also failing due to memory allocation
resize2fs: Memory allocation failed while trying to resize /dev/c/c
I don't own a v2 - but if you know of a place where the amount of memory is displayed, you should check to make sure that it is seeing 256MB.
I also suggest a memory test from the boot menu (http://www.readynas.com/download/documentation/HM/ReadyNAS_Duov2_NV+v2_HW_en_19-Sept-11.pdf ). Unfortunately Netgear doesn't disclose how to tell if the test passed/failed. But you could take a short video, and post the link here, they should be able to interpret the results here.
Are you the original purchaser? If so, when did you purchase? The warrany is 3 years. If you are still covered I think you have have enough evidence of a hardware fault that they should diagnose it w/o charge
Raaahbin
This is the entirety of mem_info.log:
MemTotal: 246820 kB MemFree: 24704 kB Buffers: 5540 kB Cached: 60848 kB SwapCached: 18348 kB Active: 66812 kB Inactive: 96552 kB Active(anon): 41012 kB Inactive(anon): 56412 kB Active(file): 25800 kB Inactive(file): 40140 kB Unevictable: 376 kB Mlocked: 0 kB SwapTotal: 524268 kB SwapFree: 495600 kB Dirty: 296 kB Writeback: 0 kB AnonPages: 80176 kB Mapped: 13952 kB Slab: 20804 kB SReclaimable: 4624 kB SUnreclaim: 16180 kB PageTables: 2172 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 647676 kB Committed_AS: 726704 kB VmallocTotal: 385024 kB VmallocUsed: 940 kB VmallocChunk: 382812 kB
And this is memory.log:
SZ: 256 AT: SDRAM
Looks to me like it can definitely see 256MB. But now I'm going to have a go at that memory test, so at least I have the results when talking to support.
