Raaahbin
Sep 15, 2015Aspirant
Replaced failing disk in NV+ v2 - both volume expansion and volume scan fail
Hi folks, I'm getting some slightly peculiar behaviour from my NV+ v2, and would really appreciate some help in troubleshooting. A week or so ago, I started getting errors on disk 1 of my NAS...
BaGRoS
Sep 21, 2015Aspirant
I have same config
4TB
3TB
4TB
3TB
WD RED
Mon Sep 21 06:39:53 Volume expansion failed
Mon Sep 21 06:25:42 System is up.
Mon Sep 21 06:23:50 Incompleted file system expansion detected. Resuming...
Mon Sep 21 04:51:07 Volume expansion failed
Mon Sep 21 04:34:09 System is up.
Mon Sep 21 04:32:24 Incompleted file system expansion detected. Resuming...
Sun Sep 20 23:43:19 RAID sync finished on volume C.
Sun Sep 20 18:32:37 Volume expansion failed
Sun Sep 20 18:15:36 System is up.
Sun Sep 20 18:13:44 Incompleted file system expansion detected. Resuming...
Sun Sep 20 13:17:58 RAID sync finished on volume C.
Sun Sep 20 08:09:05 Volume expansion failed
Sun Sep 20 07:50:59 System is up.
Sun Sep 20 07:49:11 Incompleted file system expansion detected. Resuming...
Sat Sep 19 21:14:18 System is up.
Sat Sep 19 21:13:13 Continuing with volume expansion. Do not interrupt the system during this time. When complete, email notification will be sent to the alert contact list.
Sat Sep 19 19:34:45 Found space that can be used to expand capacity, expansion process will start during next boot.
Sat Sep 19 19:34:36 Data volume has been successfully expanded to 8326 GB.
Sat Sep 19 18:25:33 System is up.
Sat Sep 19 18:23:47 Incompleted file system expansion detected. Resuming...
Sat Sep 19 18:19:45 RAID sync finished on volume C.
Sat Sep 19 18:19:07 Newly added drive has more space to expand the volume, will start volume expansion.
Fri Sep 18 12:46:02 System is up.
Fri Sep 18 12:45:09 Data volume will be rebuilt with disk 1.
And exactly the same problem.
Did you find any solution? This is due perhaps to the limit of 8GB.
Now showing me 5.6GB free from 8.1GB
Would do well to find a solution to the ReadyNAS started normally....
BaGRoS
I found some solution
but
root@nas-JohnyB:~# apt-get install lsof
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
libupsclient1 libpcap0.8 cracklib-runtime libnss-mdns libcrack2 libcap-ng0
libavahi-client3 libnet1
Use 'apt-get autoremove' to remove them.
The following NEW packages will be installed:
lsof
0 upgraded, 1 newly installed, 0 to remove and 107 not upgraded.
Need to get 282 kB of archives.
After this operation, 455 kB of additional disk space will be used.
Err http://ftp.us.debian.org/debian/ squeeze/main lsof armel 4.81.dfsg.1-1
404 Not Found [IP: 128.61.240.89 80]
Failed to fetch http://ftp.us.debian.org/debian/pool/main/l/lsof/lsof_4.81.dfsg.1-1_armel.deb 404 Not Found [IP: 128.61.240.89 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I don't now how umount /c :/ for offline resizing
- StephenBSep 21, 2015Guru - Experienced User
Do you have an ultra or a pro? Or an NV+ v2?
- BaGRoSSep 21, 2015Aspirant
NV+ v2
- RaaahbinSep 22, 2015Aspirant
After creating and turning on a swap volume on a 16Gb USB stick (just happened to be what I had lying around - I think any size would do), I logged in by SSH and entered the command:
resize2fs -p /dev/c/c &
When that process completed - which it did no trouble once I had added the extra swap space - I had all the space I should have had.
The 8TiB expansion limit is compared to your original volume size. What did you start with? I started with two 3TB disks, so I had not hit that limit at 4+4+4+3TB, but would have hit it at 4+4+4+4TB.
