Raaahbin
Sep 15, 2015Aspirant
Replaced failing disk in NV+ v2 - both volume expansion and volume scan fail
Hi folks, I'm getting some slightly peculiar behaviour from my NV+ v2, and would really appreciate some help in troubleshooting. A week or so ago, I started getting errors on disk 1 of my NAS...
BaGRoS
Sep 21, 2015Aspirant
I found some solution
but
root@nas-JohnyB:~# apt-get install lsof
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
libupsclient1 libpcap0.8 cracklib-runtime libnss-mdns libcrack2 libcap-ng0
libavahi-client3 libnet1
Use 'apt-get autoremove' to remove them.
The following NEW packages will be installed:
lsof
0 upgraded, 1 newly installed, 0 to remove and 107 not upgraded.
Need to get 282 kB of archives.
After this operation, 455 kB of additional disk space will be used.
Err http://ftp.us.debian.org/debian/ squeeze/main lsof armel 4.81.dfsg.1-1
404 Not Found [IP: 128.61.240.89 80]
Failed to fetch http://ftp.us.debian.org/debian/pool/main/l/lsof/lsof_4.81.dfsg.1-1_armel.deb 404 Not Found [IP: 128.61.240.89 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I don't now how umount /c :/ for offline resizing
Raaahbin
Sep 22, 2015Aspirant
After creating and turning on a swap volume on a 16Gb USB stick (just happened to be what I had lying around - I think any size would do), I logged in by SSH and entered the command:
resize2fs -p /dev/c/c &
When that process completed - which it did no trouble once I had added the extra swap space - I had all the space I should have had.
The 8TiB expansion limit is compared to your original volume size. What did you start with? I started with two 3TB disks, so I had not hit that limit at 4+4+4+3TB, but would have hit it at 4+4+4+4TB.
