Calisto
Nov 21, 2012Aspirant
Replacement NV+ unit received.... what next?
Hi, Today i received my replacement NV+ (v1) as my original units' PSU died and took some of the logic board with it. i have swapped the 1GB memory from my old unit into the new one but am yet t...
Calisto
Nov 22, 2012Aspirant
UPDATE
I installed the drives in the same order as they had previously been in my old unit and switched on the NAS.
After a lengthy file system check (approximately 2 hours) the unit booted up and all my shares and files are back!
I updated the firmware to the latest version and then rebooted.
I then shutdown the device, installed my 1GB memory stick and then restarted it.
Everything is okay and back to normal :D
