SMPTUK's avatar
SMPTUK
Replacement Power Supply ReadyNAS Duo RND2000
Hi all
I been checking but to date unable to locate somewhere to get a replacement power supply for my ReadyNas Duo 2000 V2.
Seem to be plenty of non Netgear options, but im not sure these are suitable.
Anyone ordered  a supply that can at least verify it works
I live in UK btw.
Many thanks
    • SMPTUK's avatar
      SMPTUK
      Many thanks
      That article confirms it is a V1 with the recessed power connection.
      All very weird that it states V2 as a sticker !
      Regards
      • Marty_M's avatar
        Marty_M
        NETGEAR Employee Retired
        Hello SMPTUK,
        The v2 refers to revision not the hardware version. To double check you could PM(Private Message) me the serial number of your NAS then I will try to check it on our system. Do not post serial here on the thread.
        Marty_M
        NETGEAR Community Team
  • StephenB's avatar
    BozeWolf wrote:
    The answer is no. I don't have a backup. What would you suggest if I did have a backup?
    I can't (and won't) speak for Marty_M, but personally I do take the backup status into account when I offer troubleshooting advice.  Some steps have risk, and I try to minimize that if the user has no backup.
    Also I want to alert users if I think they are at risk of data loss - and you are.  Though your symptom appears minor, there are root causes that aren't so minor.
    • Sandshark's avatar
      Sandshark
      Sensei
      I have used non-Netgear 12V 5A supplies with the DuoV2 and Pro2.  The 12V connector is the standard 5.5mm/2.1mm one.   I would avoid supplies intended exclusively for LED lighting and go with ones designed for surveilance cameras, since the cameras need better regulation than LED lighting.  And a UL listing is always a good thing, too.
      The model I purchased most recently is CS-1205000 and they work fine.  It has a 100-240VAC input and standard computer style removable cord, so should wiork for you in the UK.  They are available on Amazon, eBay, and lots of other places (though I have not noted any specifically in the UK).
ProSupport for Business
