d1GaeR
Dec 06, 2012Aspirant
Replaces 2TB with 3TB but only sees 2TB
Hi, I have a ReadyNAS Duo v2 running v5.3.7. My configuration was Flex-RAID in JBOD, where I had separate c and d volumes. Both drives were 2 TB. I use a second NAS to do the backup through Rsyn...
TeknoJnky
Dec 13, 2012Hero
JBOD volumes don't support expansion.
raid 1/5/6 volumes are expandable.
since you appear to have backups, you should be able to simply remove the offending volume, then recreate a new 3tb volume.
