d1GaeR
Dec 06, 2012Aspirant
Replaces 2TB with 3TB but only sees 2TB
Hi, I have a ReadyNAS Duo v2 running v5.3.7. My configuration was Flex-RAID in JBOD, where I had separate c and d volumes. Both drives were 2 TB. I use a second NAS to do the backup through Rsyn...
TeknoJnky
Dec 13, 2012Hero
delete the volume via the web volume management page, don't remove the disk.
once you remove the 2tb volume, you should be able to create a new 3tb volume in the available space.
