TobyE
Oct 10, 2013Guide
Replacing Failed Drive Possible Bug?
Yesterday I replaced on of the 3TB drives in my RN312. It was in the second bay. I left the NAS powered up, removed the drive in bay 2, replaced the drive with an identical new drive and reinserted ...
herfkr
Sep 02, 2014Aspirant
I got today the same issue, replacing a perfectly healthy harddisk
Tue Sep 2 2014 11:34:17 Disk: Disk Model:TOSHIBA DT01ACA100 Serial:23S1U5 has been removed from Channel '2' of the head unit.
Tue Sep 2 2014 11:36:01 Disk: Disk Model:WDC WD30EFRX-68AX9N0 Serial:WD-WMC1T2133 has been added to Channel '2' of the head unit.
Tue Sep 2 2014 11:36:19 Volume: Rebuilding started for Volume 'data'.
Tue Sep 2 2014 11:36:21 Volume: Volume 'data' health changed from 'UNPROTECTED' to 'DEGRADED'.
Tue Sep 2 2014 11:36:24 Disk: System will be shut down in 30 minutes because of disk failure.
Tue Sep 2 2014 12:00:47 Miscellaneous: Snapshot 'c_1409652046' is successfully created for share or LUN 'rsyslog'.
Tue Sep 2 2014 12:10:53 System: ReadyNASOS service or process was restarted.
Tue Sep 2 2014 12:10:54 System: ReadyNASOS background service started.
Tue Sep 2 2014 12:10:54 Volume: Volume 'data' is 'DEGRADED'.
Tue Sep 2 2014 12:11:10 Volume: Rebuilding started for Volume 'data'.
RN312 6.1.8
So thanks to this message I am not so much worried any more...
Patience..
RN312 6.1.8
Patience..
