Saram
Oct 12, 2020Aspirant
Replacing HDD RN104 jbod volume creation option?
Good afternoon, I have 4x2TB HDD in my RN104 for storage purposes only (Type: jbod) I wanted to replace my 2TB HDD (#4) so I bought a 4TB HDD WD Red I did the following: 1) Backup the 2 TB HDD (#...
- Oct 12, 2020
Thank you for your prompt reply.
I will test the 4TB HDD using the manufacturer's tool as you suggest and let you know the results.
Yep, you were right. My first DOA in many years. :(
Time to contact WD.
Thank you for your help
Saram
Time to contact WD.
