yoyo173fr
Aug 24, 2015Tutor
Replication between 2 NAS on private network
Hi I've a NAS on a private network. I want to buy a second one and install it on a different location on another private network. I want to know 1) if it's possible to connect both to netgea...
GregSo
Oct 20, 2015Aspirant
Hello Stephen,
I am looking to replicate data between two NAS devices(2120v2 and 3130) which are in separate geographic locations but on the same WAN and share a VPN tunnel.
Most of the Shares are iSCSI connected virtual machines in VMWare.
I would like to have data copied and stored from each of those devices to one another for redundancy purposes. Although I believe that iSCSI shares are not able to be replicated on this NAS. If that is the case, can you suggest an alternative to this?
Oct 20, 2015Guru - Experienced User
AFAIK both frontview backup and replicate are for file-based storage only, and won't work for block-based storage like iSCSI.
Perhaps run rsync in a VM that accesses both the primary and the backup LUNs???
- GregSoOct 27, 2015Aspirant
Thanks for the response Stephen,
I was thinking of assigning the VM a NFS type storage, then syncing it over to my other NAS.
