Joe-9O
Jul 08, 2019Aspirant
Request for advice on expanding NV+ RND4000 disks
I have read through several threads but have not been able to find what I'm looking for. Apologies in advance if I miss a post that would have answered my request. I have an NV+ V1, with 4 x 500Gb d...
- Jul 08, 2019
@Joe-90
Yes your NAS is configured on X-RAID so it will automatically expand your volume as soon as the the last disk re-sync completes. See OS 4 Manual page 18. You have to replace the failing disk first and let it re-sync then proceed with the 3 other disks one at a time. With OS 6 Increase in storage space will start once 2nd disk replaced on RAID 5 Config has finished re-syncing.
Also, backing up your data before expnading is also advised and best practice.
HTH
Regards
Marc_V
Jul 08, 2019NETGEAR Employee Retired
@Joe-90
HTH
Regards
- Joe-9OJul 08, 2019Aspirant
Thank you for this very fast response. Really appreciated.
- SandsharkJul 08, 2019Sensei
But ignore the approved drives list for the NV+, it's woefully out of date. Any NAS or Enterprise drive is a good choice (except archoive drives, of course). The list for a newer 4-drive NAS would be a good guide.
Thank you for that further clarification!
