forty_green
Nov 06, 2014Aspirant
Rescue from failing drives #24146691
My 5-year old NV+ recently showed "Kernel panic" on the display and was inaccessible through Windows Explorer, Frontview etc. It did not respond to the power button but after pulling the plug I manag...
forty_green
Nov 07, 2014Aspirant
I've PMd you with text pasted from what look to be the relevant logs. Also I attached a zip file of all logs, exactly as created by the diagnostics in Front View, as indicated in Useful Links. I'm just waiting for my new drives to be delivered by mail and the NAS remains powered down. Depending on your assessment of the logs, I'm minded to try the USB backup first. If that fails then I'll resort to dd_rescue as you recommend. I have just realised from another thread entitled "Will my NV+ need a factory reset" that I may need to reset too, because I'll be inserting 2Tb disks and don't think I have 4k sector alignment as start sectors are not divisible by 8, in spite of running RAIDiator 4.1.7. Is that correct?
Disk /dev/hdc: 999.9 GB, 999991611392 bytes
255 heads, 63 sectors/track, 121575 cylinders, total 1953108616 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hdc1 2 4096001 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096002 4608001 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hdc3 4608002 1953092233 974242116 5 Extended
/dev/hdc5 4608003 1953092233 974242115+ 8e Linux LVM
Disk /dev/hde: 999.9 GB, 999991611392 bytes
If so, it seems the strategy would then be to restore from USB backup to the two brand new drives and forget about synching from the old failing ones. Thanks again
