forty_green
Nov 06, 2014Aspirant
Rescue from failing drives #24146691
My 5-year old NV+ recently showed "Kernel panic" on the display and was inaccessible through Windows Explorer, Frontview etc. It did not respond to the power button but after pulling the plug I manag...
mdgm-ntgr
Nov 17, 2014NETGEAR Employee Retired
8. The NAS picks up an I.P. address via DHCP after a factory reset. If you assigned a static I.P. for the NAS on your DHCP server (e.g. your router) then the NAS would pick me up.
Is it e.g. Gmail? if you have two factor authentication setup you need to setup an application specific password for the NAS and allow less secure apps to connect.
