simmian
Jun 23, 2011Aspirant
Restoring from USB Drive
Hi All, Recently purchased a Readynas 1500 for storage for the company I work in. Been playing around with the backups etc and found that if I backed up to USB using NTFS you have the issue with p...
Jezclayton
Why not backup to a remote pc (set up a routine in FrontView) and then take your USB backup from that if required.
That way you end up with two backup copies and can use the file format required.
