simmian
Jun 23, 2011Aspirant
Restoring from USB Drive
Hi All, Recently purchased a Readynas 1500 for storage for the company I work in. Been playing around with the backups etc and found that if I backed up to USB using NTFS you have the issue with p...
simmian
Jun 24, 2011Aspirant
The only issue I have with that is the time involved, I have about 800GB of data and for me to backup to a remote machine and then copy to USB will take hours its just frustrating that NTFS is not supported or works properly
