simmian
Jun 23, 2011Aspirant
Restoring from USB Drive
Hi All, Recently purchased a Readynas 1500 for storage for the company I work in. Been playing around with the backups etc and found that if I backed up to USB using NTFS you have the issue with p...
SubSolar
Jun 28, 2011Aspirant
Can't you just use a Linux computer to copy the data? If you don't have it installed, you can just run Linux off a boot cd.
