simmian
Jun 23, 2011Aspirant
Restoring from USB Drive
Hi All, Recently purchased a Readynas 1500 for storage for the company I work in. Been playing around with the backups etc and found that if I backed up to USB using NTFS you have the issue with p...
bassa1985
Jun 29, 2011Aspirant
Hi all
I got a ReadyNAS 3200 and It gets backed up to 2TB USB HDD which is on EXT3 format (Thanks Simmian ).
Im using Ext2fsd 0.50 to access the data on the USB on a win 7 workstation. It works :)
http://www.ext2fsd.com/
However my problem is our NAS box has couple of shares but the data which get backed up to the USB is all over the place. All the data is there but NOt according to shares. So is there any way we could backup data according to shares?
Cheers
Cheers
