whyshouldI
Nov 05, 2016Aspirant
Resync - single drive
Hi, I decided to redo the NAS strategy. 2 drives with Raid and two as JBOD. one of them is showing yellow "offline with disk state "Resync" I assumed the sync was only applicable to nore than o...
- Nov 06, 2016
Hi whyshouldI,
Just to confirm, you have a total of (4) drives? Two of them in a RAID and the other two in JBOD?
I have not experienced it myself but it might be syncing on the volume configured with RAID; probably a RAID 1 if its two drives. Normally on a ReadyNAS, syncing clears itself out. It should show an ETA on the ReadyNAS Web UI as well.
Nov 05, 2016Guru - Experienced User
That's quite odd. I'd never seen one of my JBOD volumes show "resync"
- FramerVNov 06, 2016NETGEAR Employee Retired
Hi whyshouldI,
- whyshouldINov 06, 2016Aspirant
Thanks for the responses - yes it did clear itself
Cheers
