whyshouldI
Nov 05, 2016Aspirant
Resync - single drive
Hi, I decided to redo the NAS strategy. 2 drives with Raid and two as JBOD. one of them is showing yellow "offline with disk state "Resync" I assumed the sync was only applicable to nore than o...
- Nov 06, 2016
Hi whyshouldI,
Just to confirm, you have a total of (4) drives? Two of them in a RAID and the other two in JBOD?
I have not experienced it myself but it might be syncing on the volume configured with RAID; probably a RAID 1 if its two drives. Normally on a ReadyNAS, syncing clears itself out. It should show an ETA on the ReadyNAS Web UI as well.
FramerV
Nov 06, 2016NETGEAR Employee Retired
Hi whyshouldI,
whyshouldI
Nov 06, 2016Aspirant
Thanks for the responses - yes it did clear itself
Cheers
