aks-2's avatar
aks-2
Apprentice
Jan 16, 2019
Resync after power failure
I had a power failure yesterday, and my ReadyNAS NV+ v2 had no backup power source (UPS), so it went down and remained off. There were no users of the unit at the time, not for many hours in fact, bu...
  • StephenB's avatar
    Jan 17, 2019
    aks-2 wrote:
    There were no users of the unit at the time, not for many hours in fact, but once I powered it up, it started a resync.  Everything looks good.
    What would be a good way to verify that I have not lost or corrupted files, or should I just reset everything back to defaults and restore a backup now?
    I don't own a v2 NAS.  But I believe the system is designed to do a resync whenever it detects an unclean shutdown - which it would do in this case.
    It seems pretty unlikely that there would have been cached writes, given that no one had been using the NAS for hours.  The volume mounted normally, which is also a good sign.  So I think the odds of file corruption is low.
    If you are concerned, then perhaps use a file verification tool to compare the NAS files against your backup.  If something doesn't compare, then check the file dates, and see if it was updated after the backup was run.  That would be less disruptive than doing a factory reset.
ProSupport for Business
