ieeevhdl
Nov 04, 2012Aspirant
Resync after power failure
I lost power to my ReadyNas NV due to Hurricane Sandy but repowered it when the power came back on. RAIDer version 4.1.10 is reporting that Resync is 8% complete and it will take 4 hours and 20 minut...
mdgm-ntgr
Nov 04, 2012NETGEAR Employee Retired
Those errors could have been caused by briefly using those disks with old firmware that they aren't compatible with.
Looks like you've had at least some of those disks a long time. So it's quite likely that one of them is failing.
You might wish to try powering down the NAS, removing the disks (label order), hook them up to your PC and check the SeaGate disks using SeaTools and check the WD disks using WD Lifeguard Diagnostics.
