ieeevhdl
Nov 04, 2012Aspirant
Resync after power failure
I lost power to my ReadyNas NV due to Hurricane Sandy but repowered it when the power came back on. RAIDer version 4.1.10 is reporting that Resync is 8% complete and it will take 4 hours and 20 minut...
vandermerwe
Nov 05, 2012Master
Yes you are correct, you are hoping that only one disk has gone; I would be.
Do you have a backup?
The alternative approach is to try booting with a single disk removed at a time. Just make sure you label the disks for position, and don't remove or add without first powering down the Nas.
If you remove the faulty disk, the unit should boot.
