ieeevhdl
Nov 04, 2012Aspirant
Resync after power failure
I lost power to my ReadyNas NV due to Hurricane Sandy but repowered it when the power came back on. RAIDer version 4.1.10 is reporting that Resync is 8% complete and it will take 4 hours and 20 minut...
Nov 05, 2012Guru - Experienced User
Lifeguard will not recover anything - what you should be doing is running the diagnostics (and not running the destructive write test (which zeros the drive).
ieeevhdl wrote: ...Are you aware of any pitfalls if I remove one of the faulty disk to connect to a PC and try to recover it using WD Lifeguard Diagnotics? I am afraid of the WD tools attempting to recover the disk but do succeed or not succeed and making it worst for ReadyNAS to recognize the volume.?...
If you are connecting to the internal SATA and power connectors in the PC, be careful to do this with the PC powered down.
