Arnaud73
Mar 05, 2012Aspirant
Resync and "Vol C Lifesupp!"
Hi, I just got a problem with my ReadyNas Ultra 4 at the worst time. My Ultra 4 was equiped with 4 drives : - 1 : WD20EARS - 2 : WD15EARS - 3 : WD20EARS - 4 : WD15EARS A few weeks ago, I ...
Arnaud73
Mar 08, 2012Aspirant
mdgm wrote: When the NAS is in tech support mode it needs to pickup an IP address (be assigned via DHCP). Then if the secure tunnel doesn't work port 23 needs to be forwarded to the IP address of the NAS as Thomas-xh mentioned above. If you can do that PM him the IP address.
Thanks for the update.
In addition to having problems with the ReadyNas, I could not boot my old Linux box that was put to storage... This means that I don't have a simple solution right now to forward a port of my ADSL connection to the ReadyNas.
If I change the network configuration, I can have the ReadyNas get an internal IP address directly from the (basic) router. In that case, will the ReadyNas initiate the secure tunnel with Netgear ? Or will I really have to have port forwarding?
Thanks in advance!
