Marowista
Oct 17, 2013Aspirant
Revert back from Wheezy to original firmware on Pro RNDP6000
Recently I bought a ReadyNAS Pro RNDP6000 v1. Because I was unsatisfied with the possibilities of Debian 4, I migrated to Debian Wheezy. I did this fully aware of breaking the warranty. Using a con...
mdgm-ntgr
Oct 17, 2013NETGEAR Employee Retired
A USB Boot Recovery would load the stock firmware back onto the internal flash: http://home.bott.ca/webserver/?p=166
Though unsupported you can run ReadyNAS OS 6 on the Pro. This uses Wheezy. You might also wish to consider this.
