Marowista
Oct 17, 2013Aspirant
Revert back from Wheezy to original firmware on Pro RNDP6000
Recently I bought a ReadyNAS Pro RNDP6000 v1. Because I was unsatisfied with the possibilities of Debian 4, I migrated to Debian Wheezy. I did this fully aware of breaking the warranty. Using a con...
Marowista
Oct 19, 2013Aspirant
I've applied the USB recovery and after a OS Reinstall and Factory Defaults I got it working in it's original mode...kind of.
I can set up the device now using Raidar and when I create an RAID array I can access the data I place on it. However, the Frontview interface doesn't seem to be working properly: I can login to the normal and admin interface using the default username/pass, but it won't show me any content.
I do see the frontview images but the menu's and everything is gone. I've tried the USB recovery again as well as the reinstall/factory defaults but this doesn't work. Now I've tried setting the device up in Tech Support but I don't know the telnet password to check it.
Any suggestions?
Any suggestions?
