pfrehner
Apr 26, 2019Guide
RN 102 update firmware from 6.9.5 to 6.10.0 and now won't boot UGH!!
updated firmware to 6.10.0 on RN102 and now won't boot
did a firmware update from 6.9.5 to 6.10.0 this morning and after completed, the blue power light just flashes once a second. ...
quickly_now
Apr 28, 2019Apprentice
More information:
The changes to 6.10.0 (and hotfixes) need these alterations to make subversion work.
Step 1.
Locate the SUBVERSION.conf file that was set up (in the previous instruction, many years ago), it should be in /etc/apache2/conf.d
Move that to /etc/apache2/conf-available
Step 2.
Make a softlink from /etc/apache2/conf-enabled, called SUBVERSION.conf, and linked to the file in /etc/apache2/conf-available:
cd /etc/apache2/conf-enabeld
ln -s ../conf-available/SUBERSION.conf SUBVERSION.conf
Step 3.
edit the SUBVERSION.conf file in /etc/apache2/conf-available, to REMOVE all references to loading libraries (for whatever reason it does not seem to be needed).
Step 4.
Restart apache:
systemctl restart apache2
This got my subversion via HTTP working again (bear in mind my configuration in that file gives me a subversion URL of HTTP://nas/svn/ )
So far... success. The next worry is what will happen on reboot.
- pfrehnerApr 28, 2019Guide
I found a solution to my issue - after a bunch of reading and finger crossing
I accessed the boot menu and did the "OS Reinstall"
https://kb.netgear.com/22892/How-do-I-access-the-boot-menu-on-my-ReadyNAS-102-202-212-or-312
it booted right back up.
something went south during the firmware update. not trusting the readynas much anymore - will be moving my files off to cloud drive (onedrive)
this is the last straw with netgear
