Angeld
Dec 17, 2015Aspirant
RN 104 LED Says PAGE_ADDRESS+8
Hi I have a RN104 and decided to upgrade to firmware 6.4.1. and after rebooting my led screen says PAGE_ADRESS+8 its been that way for around 4 hours. I know the release notes say it has to do a scan after installation but its getting me worried going on 4+ hours of doing this. Does anybody have any idea what PAGE_ADDRESS+8 means? Or is it just mean its still scanning the hard drives?
Also can access the device through web or smb services.
Also have a question as to if I can take out my hard drives and put them in a newer more powerfull ready nas with out loosing any data or do I need to find a way to back it up before then?
Hello Charles
Thanks for the info. I ended up trying to talk to tech support but they quickly had to escalate the case and looks like they want me to pay for help with it even though its still under warranty. I decided to just turn it unplug it and try to do a USB install of the os. That went quickly and it rebooted fine. I was able to login in and access the admin panel and noticed it started to sync the volume data. Well after about 30 min of that it gave the same error. So I just unplugged it and started plugged it back in it booted back up fine again and went back to syncing the volume data.
I though for a min and since its so underpowered system I went in and turned off all the apps I had incuding Virus-Scan and all of the services I dont really need like FTP and itunes. Its been running for 12 hours now no problem still syncing the data though. I have been able to look around the shares and copies a file off and seems to work. Both SMB and AFP are working for me. But I don't want to mess around too much till its done.
I also don't seem to have much luck with the ReadyNAS recently. Bought a RN315 to upgrade from my RN104. Got it suck a scratch drive in like what was recommended. Updated to 6.4.1 was just messing around with settings and loading apps. Rebooted the NAS and itgave me a lcd message of "mount_boot_root +1e9" and I as unable to see the device on any of my comps. Was unable to get in to the boot menu or even do a usb os install either. Tried diffrent drives also and nothing so its getting sent back. Not sure what I want to end up doing now.
Anyways thanks again for the info I will let you know how my RN104 is working after its done syncing the data in about 70 hours or so the admin page says it will take.
- mdgm-ntgrNETGEAR Employee RetiredThat is a kernel error message. I would leave the unit running overnight and see where it is at in the morning. If you have just updated to 6.4.1 from firmware prior to 6.4.0 the update could take quite some time. As for moving to a newer more powerful model you should: 1. Put a scratch disk (must not be from your array) in the new ReadyNAS 2. Update the firmware on the new unit to at least as new firmware as what you were running on the old unit (preferably the same firmware - could be easiest to update both units to the latest firmware if the old unit is still working) 3. Verify the update was successful 4. Power down, remove the scratch disk 5. Move your disks across. Note that if a problem is on the disks it will remain when moving the disks to a more powerful ReadyNAS. The OS is installed onto the disks.
- AngeldAspirant
Ok thanks I will let it run overnight. Yea I was upgradeing from 2.4 I hope I dont have a problem on the disks used mainly as a media server and file storage lots of work lost if they are bad. Also thanks for the info on upgradeing the unit. Was looking at going to a 314 and that info helps. Gosh
- AngeldAspirant
No luck its now been on for about 16 hours and still says PAGE_ADRESS+8.
- AngeldAspirant
Getting really worried now at 28+ hours. Well I have a new 315 on its way to me it will be here tomorrow. Any ideas if will be able to upgrade it like you said and not loose my data or am I gonna be sol?
- Magic_CrazyAspirant
Hello,
I have the exact same problem. I upgraded my RN104 from 6.2.5 to 6.4.1, since I can see the same error message on the LED Screen.
When I boot it, I have access to te administration page. After some minutes, The error message appears, and I have to unplug it from AC in order to reboot it (even push the power button for long seconds doesn't work).
I think this might be a problem with Samba sharing, as the error appears earlier if I try to access the files from my Windows PC. I didn't try other services for now.
As I'm writing, I booted the NAS without network plugged in, and I don't see the error appearing. I'll investigate further. In the meantime, if you need anything from me, I'll do my best.
Charles.
