wayne2101
Nov 20, 2016Tutor
RN 214 start up issues.
I am unsure if this is a good thing or have I wasted a bit of money? I am attempting to use my RNAS Device over the cloud, but that is just another issue. I have 4 discs installed and all are wor...
- Nov 20, 2016
All seems working fine after the firware update (fingers crossed) now to go to the Cloud issue community. Many Thanks.
mdgm-ntgr
Nov 20, 2016NETGEAR Employee Retired
Could you disable WoL and then update to 6.6.0 and see if you still have the same issue?
- wayne2101Nov 20, 2016Tutor
I have read the directions for the Firmware upgrade to go to the lower version before going on to version 6 and now have the code al_eth_set_wol+54.
Once I get the system up and running I shall hopefully give further information. The WOL function is now disabled.
