sfpegasus
Jan 23, 2017Tutor
RN 312 Firmware 6.6.1 Strange backup errors
Ever since the update, I keep receiving the following error: Backup job Daily is already in progress. Consider adjusting backup schedule. I have a daily backup job (external usb) that has a...
sfpegasus
Jan 30, 2017Tutor
This is apparently bigger than a couple of backup errors. Disabling the antivirus has returned my system back to normal. The antivirus upgrade in 6.6.1 is buggy as all hell. It's apparently the cause of my other post "ReadyNAS 312 ERROR System: Fan fan2 in enclosure Internal speed is below threshold".
Monitoring the antivirus definition file updates led me to find that my failures were happening right after these updates.
FramerV
Jan 30, 2017NETGEAR Employee Retired
Hi sfpegasus,
I see, it could be related to the link below:
Lots of Virus detection after 6.6.1 Update
