kbachler6
Dec 04, 2019Aspirant
RN 314 Issues after updating to OS 6.10.2
After updating to 6.10.2, I can no longer see any network shares other than the Home folder. Prior to updating, I had a share named Home; that is now part of the Home folder, and appears there when ...
- Dec 05, 2019
On Home-1 it might be best to create a new share, copy the contents of Home-1 into it, delete Home-1, and then rename the new share (to something other than Home).
On the main issue, try running the Windows Command prompt and enter
net use * /delete
net use t: \\nas-ip-address\data /user:admin nas-admin-password
using the real NAS ip address and admin password of course. Be careful on the typing - particularly spaces and the slash direction.
The first command closes any network sessions open on the PC. The second maps the full data volume to drive letter T. You should see all the shares, Data, and Home on that drive letter if it works.
Dec 05, 2019Guru - Experienced User
I'm surprised the system let you do that, as it is a duplicate share name. FWIW, it's a bad idea to give a share the same name as the data volume (normally called Data) or Home.
kbachler6 wrote:
I had a share named Home; that is now part of the Home folder, and appears there when accessing over the Network via Win 10 explorer, even though I renamed the folder to Home-1.
You are accessing with the NAS admin credentials? (normally seeing the data volume, home, and admin when you access with file explorer)? Or are you saying that Home is now part of your private share (which isn't named Home).
How did you rename the folder? (Windows explorer, or the web ui)? You shouldn't rename them from Explorer.
- kbachler6Dec 05, 2019Aspirant
StephenB wrote:
kbachler6 wrote:Prior to updating, I had a share named Home; that is now part of the Home folder,
kbachler6 wrote:I had a share named Home; that is now part of the Home folder, and appears there when accessing over the Network via Win 10 explorer, even though I renamed the folder to Home-1.
I had a share called "Home" prior to the upgrade and didn't realize that in the upgrade "Home" would take on a meaning that it didn't previously have, or I would have renamed it prior to the upgrade. I renamed the share I created called "Home" to "Home-1" (not the Home default share on the server). Now when I look at the server with Windows with Explorer, the ONLY folder I see on the server is Home, with the contents of the Home-1 folder (which is under a Share called "Documents")
However, I have numerous other shares: "Documents", "Music", etc., all available to Everyone (as well as admins), all available anonymously, none visible from Windows Explorer. Via the web and browser-interface, the shares are listed as <server>/data/<sharename>. That can't be accessed via Windows, and nor can <server>/<sharename> except for <server>/Home.
I renamed the folder through the browser interface.- StephenBDec 05, 2019Guru - Experienced User
net use * /delete
StephenB wrote:On Home-1 it might be best to create a new share, copy the contents of Home-1 into it, delete Home-1, and then rename the new share (to something other than Home).
net use * /delete
Hi,
Tried the share creation, copy, etc. No impact.
Tried issuing the "net use" commands. Both gave: "System error 67 has occured. The network name cannot be found."
