kbachler6's avatar
kbachler6
RN 314 Issues after updating to OS 6.10.2
After updating to 6.10.2, I can no longer see any network shares other than the Home folder.  Prior to updating, I had a share named Home; that is now part of the Home folder, and appears there when ...
  • StephenB's avatar
    Dec 05, 2019
    On Home-1 it might be best to create a new share, copy the contents of Home-1 into it, delete Home-1, and then rename the new share (to something other than Home).
    On the main issue, try running the Windows Command prompt and enter
    net use * /delete
    net use t: \\nas-ip-address\data /user:admin nas-admin-password
    using the real NAS ip address and admin password of course.  Be careful on the typing - particularly spaces and the slash direction.
    The first command closes any network sessions open on the PC.  The second maps the full data volume to drive letter T.  You should see all the shares, Data, and Home on that drive letter if it works.
ProSupport for Business
