AlanBoats
Nov 05, 2025Aspirant
RN 422 Volume recovery
Hi all, Hopefully someone out there will have the expertise to help me recover my data. I have a RN 422 with 2 x 4TB drives running in Raid 1 configuration. All has been good until a month a...
Nov 05, 2025Guru - Experienced User
AlanBoats wrote:This is what I can see if I log into my NAS. Disk 1 is the original and Disk 2 is new blank and formatted.
First: DON'T remove the volumes - that will make data recovery much harder (likely impossible).
There could be more information in the full log zip file (which you can download from the logs page). It can be very hard to unpack - but I can take a look at it for you. If you'd like me to do that, then put it into cloud storage (dropbox, google drive, etc), and send ma a private message (PM) with a link. Make sure the permissions are set so anyone with the link can download. You can send a PM using the envelope icon in the upper right of the forum page.
Don't post the link publically, as there is some privacy leakage when you do that.
AlanBoats wrote:Disk 2 is new blank and formatted.
Do you still have the original disk 2? (intact, not reformatted)?
