ittim
Oct 22, 2012Aspirant
RN Pro2 VM Datastore ESXi 5 issue
Hi All,
I set up our RN a while back as a datastore for a ESXi 4.1 server. After some dificulties Its now working well.
I've now got an ESXi 5.0 server that I want to access the same datastore with. I've added the ip address for 5.0 alongside that of my 4.1 server in the NFS settings in 'write enabled hosts' and 'root privilage-enabled hosts' but I can't add the store.
ESXi 5.0 gives me the following error "Call "HostDatastoreSystem.CreateNasDatastore" for object "ha-datastoresystem" on ESXi "10.27.1.30" failed.
NFS mount 10.27.1.53:\data\ failed: The mount request was denied by the NFS server. Check that the export exists and that the client is permitted to mount it."
Seems like a permission error but I can't figure out what it could be.
- mdgm-ntgrNETGEAR Employee RetiredIn Frontview go to Shares > Share Listing > Sharename > NFS and check the settings there
- ittimAspirantthanks for the replt mdgm,
I have Default access disabled, then below i have boxes checked for Write enabled hosts and for root privilage-enabled hosts.
The entries for both read 10.27.1.30,10.27.1.38
I'm using the share happily on esxi4 (10.27.1.38) just not 5. - mdgm-ntgrNETGEAR Employee RetiredIs your ESXi 5 server on one of those IPs?
What version of RAIDiator are you running? - ittimAspirantYes ESXi5 is 10.27.1.30
Radiator ver 4.2.21.
Thanks - mdgm-ntgrNETGEAR Employee RetiredYOu may wish to open a tech support case and see what NetGear tech support has to suggest. Post your case number.
- ittimAspirantThanks for your help mdgm.
