Dirk_
Oct 08, 2020Aspirant
RN102 - Backup job always stalls when it reaches 1.3TB - where to look?
Hi, I am usually running rsync to backup my one RN102 to my other RN102 (both 2x4TB WD Red in X-RAID, 1 volume, 10 shares). While most shares will backup fine, at one share (size ~1.8TB) the rsyn...
Oct 08, 2020Guru - Experienced User
Dirk_ wrote:
Is there any log file I can see why the backup job is stalled?
I'd look in system.log and kernel.log for disk and btrfs errors around the time of the hang.
There are a couple of other things you could try - copying the share over the network with a PC tool, and see if that also hangs. Teracopy or FreeFileSync might be good for that (or robocopy if you know how to use that). That should let you know exactly where the problem is.
If you have ssh enabled (and know how to use it), you could also try copying the share to /dev/null - which will open and read every file in the share (but not actually transfer it anywhere).
Dirk_
Hi Stephen,
thanks for your reply.
Where do I find system.log and kernel.log?
In /var/log I do not see these files...
For the backup to the external HDD I was using
"Type: USB" under Target, thus I assume this is
a pure copy approach, isn't it ?
Thanks for your help!
Dirk
- StephenBOct 08, 2020Guru - Experienced User
They are in the log zip file (which you need to download from the web ui).
If you are using ssh directly, you need to access the logs with journalctl.
a pure copy approach, isn't it ?Yes.
- Dirk_Oct 08, 2020Aspirant
I looked the log file but they are not going that far back.
Thus, I restarted the backup job now and it runs since 4h:50min
- unfortunately - only with 7.3MB/s - so will take a while...
(Don't know why the backup is now so slow.
Last time I could reach >25MB/s...)
Will keep you updated once it reaches 1.3TB boundary again.
Dirk
- Dirk_Oct 14, 2020Aspirant
Backup Job has now reached a point where it is stalled at 1 TB (still showing running with 2.1MB/s since over 145h...).
I dumped the log files and if I look into the logiles.
In system.log I only found this oneline, which sounds as a problem:
Oct 14 17:11:09 NAS-Wettmar rnutil[21427]: Failed to get tier from /dev/md0 : 25
If I look into systemd-journal it gives me:
Oct 14 17:13:12 NAS-Wettmar readynasd[2904]: /data/._share/Backup/.snapshot/b_1602170760_14627/SUSE: No such file or directory
Oct 14 17:13:12 NAS-Wettmar readynasd[2904]: 10: No such file or directory
Oct 14 17:13:12 NAS-Wettmar readynasd[2904]: Keller/dirk/.hplip.conf: No such file or directory
Oct 14 17:13:12 NAS-Wettmar readynasd[2904]: Keller/dirk/Desktop/Download/hplip-1.7.1.old2/hplip-1.7.1/hplip.conf: No such file or directory
Oct 14 17:13:12 NAS-Wettmar readynasd[2904]: Keller/dirk/Thinstation/Thinstation-2.2/packages/nx/etc/nx/nxclient.conf: No such file or directory
Oct 14 17:13:12 NAS-Wettmar readynasd[2904]: 10: No such file or directoryand this continued with many other files...
I checked on the NAS, there is not .snapshot directory in my Backup share.
Lookslike the rsync is working with a list of files which is not actual...
What can I do to clean this up?
If I look into kernel.log I get a long list of:
Oct 12 15:28:51 NAS-Wettmar kernel: mvneta d0074000.ethernet eth0: bad rx status 0f830000 (overrun error), size=768
Oct 12 15:28:51 NAS-Wettmar kernel: mvneta d0074000.ethernet eth0: bad rx status 0f830000 (overrun error), size=128
Oct 14 11:30:44 NAS-Wettmar kernel: mvneta d0074000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
Oct 14 11:30:44 NAS-Wettmar kernel: mvneta d0074000.ethernet eth0: bad rx status 0f830000 (overrun error), size=192
Oct 14 13:23:03 NAS-Wettmar kernel: mvneta d0074000.ethernet eth0: bad rx status 0f830000 (overrun error), size=272...
Thanks for any help!
Dirk
