john_grif
Apr 14, 2017Aspirant
RN102 - Blinking power light and no disks detected (OS 6.6.1) 1.3TB of data on discs
RN10200 Firmware 6.6.1 No disks detected NAS over 2 years old Cant login to admin panel Have been having issues for a few days. Admin panel dropping out. Was trying to create a USB backup .... ...
john_grif
I have put it into read only mode and haphazardly get access to the admin panel. But that drops out like before.
At least it is seeing disks now!
- StephenBApr 14, 2017Guru - Experienced User
That's good.
I suggest backing up the files over the network (connecting the USB drive to a PC). This works best if the PC is connected with wired ethernet. Drag/Drop is ok, but a copy utility that verifies would be better. Teracopy is one freeware PC tool that can do this, there are others.
Once the data is safe, we can then figure out your best option. One approach is to just do a factory reset and rebuild the NAS (restoring data from the backup).
- RackaApr 15, 2017Aspirant
Same version of software and same problem as OP. I'm happy to lose the data on the drive for now, but the factory reset did not work :( anyu ideas?
seems factory reset without the drives, then adding them one at a time, powering off for couple minutes between each step sorted my problem.
